Is it possible to add to Venus OS normal PHP environment? With php-cli at least?
yes, opkg install php-cli.
# opkg list | grep php php-fpm - 7.4.9-r0
But it is in Venus OS Large.
Is it different in Venus OS?
you need to update first to install it, see https://github.com/victronenergy/venus/wiki/commandline-introduction#opkg.
The feeds are (roughly) the same. If you have a large image of v2.80~ you need to use candidate btw. For v2.70~ you need release.
It's the same question: normal PHP environment.
The PHP on Venus OS compiled with "--without-openssl" option. So the https wrapper is disabled.
I can file_get_contents('http://....'), but not file_get_contents("https://....")
I try to run GaladrielMap on Venus OS, but most maps are available via https.
Hi, could be that https is fixed now: https://github.com/victronenergy/meta-victronenergy/commit/f7969ecb941405ab75fb8d327fd5aa1a37d10f3c
That patch is in v2.80~32, announced a few hrs ago
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
40 People are following this question.
