heinz0005 avatar image
heinz0005 asked
GX Tank 140 shows a sensor value off 21474838.0V but is only 30mV
I have the gx Tank 140 to display the Tanksensor from comworks. It was functional but now it shows on all sensors error and the sensor value is 2147838.0V from the sensor with empty tank comes a voltage of 30mV. If I disconnect the sensor the value is 0V
At setup I have : Sensor type voltage, sensor value when empty 0,1V, sensor value when full 2,5V
I try to remove all sensors, restart, power down for 10min.
The firmware at Cerbo is on 2.73, I try also v2.80-24 but the same.
Thanks for any help
Heinz
tank monitor
devodave avatar image
devodave answered ·
Sounds like your GX Tank 140 has gone faulty.
adamr100 avatar image
adamr100 answered ·
Did you get a resolution to this? I am getting it on my external power supplied tanks 3 and 4.
