i have two AC inputs on my Quattro 5000. Does someone know, whether it is possible to programm a seperate alarm with the relay. That I can see wich AC input is shutdown. (Input 1 or Input 2 or both)
Are you wanting local alarms? There is a grid lost alarm on the gx but I think it works for only input 1 I could be corrected I have never used it.
You can set up alarms on the vrm using alarm rules. Select the quattro and use the active Input parameter
25 People are following this question.
