luis-felipe-dominguez-vega avatar image
luis-felipe-dominguez-vega asked
Custom Grid configuration for ESS
Hi, I'm buy a Solar System that have a Multiplus Compact 2000VA inversor/charger and in a future i want create a ESS system with a MPPT Solar Charger and the VenusOS on my raspberry Pi. The problem is that i go to documentation and say that i need to set a Grid Code from my country, but I'm from Cuba and your doesnt have any relation with my country (i suggest to you because is a great oportunity for your solar system products).
So how I can set a custom variables of Grid Configuration that i can get from my Electricity Company (whe only have one) and use into multiplus to setup the ESS system?
MPPT ControllersMultiPlus Quattro Inverter ChargerESSgrid
Rob Duthie avatar image
Rob Duthie answered ·
Hi
You can use another country code that has same voltage and freqency rating and that will do as the all work the same way in protecting the grid.
Use the USA setting as it is 110v @ 60 Hz
Regards
Rob D
NZ
luis-felipe-dominguez-vega avatar image luis-felipe-dominguez-vega commented ·
Thanks... and if the Multiplus ask about a password??? I don't tested yet...
Rob Duthie avatar image Rob Duthie luis-felipe-dominguez-vega commented ·
email direct at, raduthie@gmail.com
