Doruk Kocuk avatar image
Doruk Kocuk asked
How to enable external control of the MPPT’s in a lithium setup with VE.Bus BMS?
Here is the setup
4x 200 Ah 12,8 Volt Smart lithium batteries
12/5000 quattro
Ve.bus bms
100/30 smart solar mppt’s connected to cerbo via ve.direct cable
Cerbo gx
Question: In case of over voltage in one or multiple cells or overheating does the bms shut down mppts?
Thanks
cerbo gx
Rob Fijn avatar image
Rob Fijn answered ·
Doruk Kocuk answered ·
Thanks Rob i know that cable but if i remove the ve.direct cables between the mppts and the cerbo we also cannot monitor the mppts vla vrm portal. When there is a canbus enabled bms in the system, the bms takes over the control of the mppts and when you connect to any mppt via VictronConnect you see that it is externally controlled. I am trying to figure out how to get them externally controlled in a setup without a canbus bms but a ve bus bms
