dsatwork avatar image
dsatwork asked
Will Multiplus II Powerassist help with low voltage in a RV Park
Will Multiplus II Powerassist help with low voltage in RV Park? If it can powerassist to help with amperage can it also kick in to help when the RV Park voltage drop from 120 to 110 or lower, will the Multiplus II Powerassist kick in to provide clean power?
powerassist
shaneyake avatar image
shaneyake answered ·
It depends on the cause of the low voltage. If the low voltage is caused by the current you are drawing then yes the multiplus can help reduce the current which would reduce the voltage drop in the cables.
If the power from the outlet is already low before you draw any current then no it won't help. Unless it disconnects from the grid connection.
You can set at which voltage it should disconnect or connect to grid.
