mxride avatar image
mxride asked
Mutiplus II Uniit and AC2
Excuse my confusion as this may have been asked (no luck finding answer).
With my Multiplus II unit, and the AC2 output. I want to wire up my heavy loads i.e. water heater, air compressor to AC2. both of which are currently wired directly to my breaker panel. for the life of me, I am struggling to understand how to wire them to AC2. Do I eliminate the these devices from the Breaker panel and wire them directly to the AC2 output?
or do I also feed the mains on then panel with AC2 (seems this would still draw from AC1) unless I had a small sub-panel.
I have AC1 feed the mains on the panel and just cant understand the wiring of AC2 back to the panel.
Thank you in advance
Mark
Multiplus-IIac out 2
marekp avatar image
marekp answered ·
@mxride
AC2 is a source of AC power for loads that will turn off when grid is lost.
If you have more of those loads, use a small panel for them and feed the AC2 output to this panel.
MultiPlus-II Product page
MultiPlus-II Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
