chrishon avatar image
chrishon asked
Smart Battery Protect disconnects momentarily
After updating a Smart Battery Protect 100 Amp to the latest firmware it now disconnects the load momentarily at what appears to be random times, it is connected to Smart Lithium batteries that rarely go below 95% charge, there is a small load 1 to 2 amps that is drawn through a Schaudt EBL111, when the disconnect happens the EBL111 switches off and disconnects all loads which requires a physical button to be pressed. I have removed the disconnect wire from the BMS to the battery protect and put the bridge wire in. The Battery Protect has the preset Lithium profile activated. Any help would be much appreciated as the button to press is 20 miles away!
Thanks in advance.
Battery Protect
giuliocanale avatar image
giuliocanale answered ·
Dear Chrishon,
did you find the reason of suddenly disconnect?
thanks.
Giulio
