Fuse blows when lead is put into B1 position on shunt. New install. Wired directly to positive battery terminal, as per instructions.
what size fuse are you using should be 1 amp, if it is and still blows please take it back to the seller and have it checked under warranty
I would try to disconnect the RJ12 cable that is going to the monitor. Than I would inspect the PCB at the shunt if there is any obvious damage.
25 People are following this question.
