info-6 avatar image
info-6 asked
Bluetooth with Venus Firmware 2.80-24
Hi there @ all,
I#ve installe the above firmware on a CERBO GX and can see that there is a menue item for Bluetooth.
If I enable it and looking under I/O for Bluetooth sensors, it only shows me the menue item "Enabled" but it obviously does not detect any sensors, such a from SmartSolar or others.
Is there a list available which sensors may be detected?
Or do I expect too much? :-)
Pleased to read something here
BRGDS
Hartmut
cerbo gx
nickdb avatar image
nickdb answered ·
2.80 is beta firmware, so you won't get support for that in this forum.
All the information is documented in the release notes on the modifications forum.
I don't believe that feature is designed to work in the way you are thinking, so please start by reading the documentation.
info-6 avatar image
info-6 answered ·
Thanks for swift reply.
I have installed it for testing since I read in another forum that it works with Ruuvitag wireless sensors. So I thought that it may works also with other Bluetooth devices :-)
BRGDS
Hartmut
synikster avatar image
synikster answered ·
Any updates on this? Any sensor other then the RUUVITAG works?
