ningaloo avatar image
ningaloo asked
Raspberry Pi USB extension / hub
I have 3 victron devices (2 X Mppt and smartshunt) that I want to connect to my Raspberry Pi via VE Direct.
When I plug the VE Direct Usb into the Pi it works as expected however my devices are 2-3 metres away from the Pi and I need to use a USB extension cable to reach them. The extension cable works ok with other devices but does not work with the victron units.
Ideally I would like to use a USB hub with a 2 metre cable and plug the individual victron devices into that. Should this work? Any recommendations for a suitable hub?
Raspberry PiVE.Direct
kevgermany avatar image
kevgermany answered ·
Make sure the hub is powered.
bluejeans avatar image bluejeans commented ·
I had this same question. I was wondering whether a hub needed to be powered. I guess it does. Have you found a hub that would power on 12v with an internal step down? Or do they all need to be externally stepped down to 5v?
Most of the hubs come with an external 12V transformer. Just make sure it can take your charging voltage.
what hub did you use?
kevgermany avatar image kevgermany ♦♦ bluejeans commented ·
Mine was RSHTECH 4 port with USB charger built in.
bluejeans avatar image bluejeans kevgermany ♦♦ commented ·
Did you cut the wall wart and connect to battery power?
