cdav3435 avatar image
cdav3435 asked
Battery Balancer Design - Conflicting Product Manuals
Hi everyone,
Trying to plan a new battery deployment for my off-grid cabin.
I'm planning on installing 4x Victron Smart Lithium Batteries - 12V/200Ah - in a 24V system (2p2s)
I'd also like to include a battery balancer to keep the two sets of series batteries balanced. As per the Battery Balancer manual, bridging the middle connections should allow a single Battery Balancer to manage all 4 batteries.
Picture from the manual for reference:
This design makes sense to me, I understand that the midpoint connections must be sized appropriately to handle load should a battery fail. However, the manual for the Victron Smart Lithium batteries mentions that midpoints should not be connected together:
Can someone provide some insight here? I don't understand why the batteries shouldn't be connected like this. Thanks for any help you can give!
Lithium BatteryBattery Balancer
nickdb avatar image
nickdb answered ·
Lithium requires a battery manager. Why would you want balancers when charging is managed intelligently with a BMS?
cdav3435 avatar image cdav3435 commented ·
I'm planning to use the Lynx Smart BMS with a few Lynx Distributors. Are the Lithium batteries capable of balancing between separate batteries in a series? The documentation only really mentions balancing between the internal cells - or maybe I've misread that...
leftcoastman35 avatar image
leftcoastman35 answered ·
Hi, did you ever get an answer on this? I have a similar setup on my boat and the battery-level voltages for each battery in a serial pair drift apart at high SOC.
Previously I would disconnect all the batteries and charge them 1 at a time, but obviously easier if I can just install a balancer to prevent the problem from occurring.
