Is there a way to set a timer on EasySolar II GX to switch on, off and charge mode ? I tried to find such options on VRM but couldn't. Any ideas please ?
I Think that the only way of doing this would be to write a custom service that controls the inverter mode via a DBus service. you would then need to get the Gx to load and run this service at every restart.
Easier would be to leave the inverter on, and set up the AES as advised under the other branch of this question.
29 People are following this question.
