kaarthik avatar image
kaarthik asked
fronius stop working with 105 error
i have 3 numbers 3 kva inverter and 10kw fronius symo inverter with Venus, when ever one of the mains input (L1 or L2 ORL3) disconnect only two phase available victron moves to inverter mode , as soon as victron moves to inverter mode fronius stop producing power and gives 105 error which is high fz. There is 2kw load and my battery around 78% still fronius in same state.mod bus settings are same as per recommend , victron set with ESS ,Then tried with pv support assistant still same result .Please confirm that its controlled by victron settings algorithm or any settings need to be adjust. Thanks.
Fronius
marekp avatar image
marekp answered ·
Is this Fronius 10kW connected to 3x3kW MPs on the their AC-out?
Is your Fronius set to work in MG50 mode?
