I have a Easy solar 2 GX which i have just connected to a 10kw generator, how do I know its charging the batteries ?
1. measure the current going into the battery,
2. measure the battery voltage and if it is going up than battery is charged,
3. watch the screen on the ES-II gx and you will see the battery SOC and current,
4. connect your ES-II gx to the network and run Remote Console. Information about battery state is there,
5. VRM portal is also a good way to see what is happening in your system.
30 People are following this question.
