justin-carver avatar image
justin-carver asked
Battery Protect and Inverter Wiring
I have a Battery Protect installed in my system with a Renogy 700W inverter connected directly to the battery via a 100A fuse. It does have a remote on/off switch panel which connects to an RJ11 style connector on the inverter. How do I wire this switch to the BP so it will disconnect with my other 12v DC loads when the BP low voltage setting kicks in?
Battery Protect
