Does the EasySolar II GX feed energy back to the grid by default? If so, how can i prevent that?
otherwise if it doesn't by default, can safely connect it to the grid ?
If you use VE Configure with a cable connection you can check, there's a setting for it. I'd guess it's OFF by default, it is on my easysolar, but it's not a II.
30 People are following this question.
