svboundless42 avatar image
svboundless42 asked
Overcharging issues
I have Victron 100/50 solar with 550w connected to my marine system with 450ah of victron LiPo4 batteries. I have the Cyrix Li Ct installed as well as the BMS 712 and the Victron battery protect. Recently when running the engine I received high voltage alarm from my AGM starter battery ( at 15.6v). House bank was still around 14.2 ( lithium).
Happened twice when motoring for longer time periods. Then the other day at the dock plugged into shore power with solar on and with the Victron Multi Invertor/Charger on charging mode got another high voltage alarm of 15.6 on the agm starter battery, but house bank at 14.2. I voltage tested the battery at the terminals both times and it was high voltage.
My alternator is a 120 amp on a Beta marine 50. Engine and alternator as well as all victron systems are only 2 years old.
Any advice on how to trouble shoot this would be appreciated. Currently in Mexico in an area with no Victron support available.
battery charging
Mike Dorsett avatar image
Mike Dorsett answered ·
Check the alternator regulator - is it limiting correctly? This should be regulated out at 14.4 - 14.8V, plus any drop included in the external voltage sensing. Also check the voltage limit set points in the inverter charger, likewise this should limit to 14.4 - 14.8V.
Also, check what happens to any remote voltage sensing, and charging drops across split charging relays, battery protect devices etc.
