mikedonner avatar image
mikedonner asked
Losing Amps??
I have an off grid fixed system with no AC in, connected to 4 battleborne batteries in parallel to a Lynx Power In. Its about 9 feet (2 feet using 2 AWG to Lynx then 7 feet much thicker 4/0 AWG) from the actual batteries to a Multiplus 12/3000/120.
When I look at the display for the inverter inside VictronConnect software app under "current" for the AC OUT it will display around 1amp, but under battery "current" it will say from 5-7amps.
Is this actual loss? And if so is that a normal loss rate?
I have networked my MPPT, shunt, and inverter. And I'm pretty sure all my settings are correct BattleBorne guided me through it.
Multiplus-IIamps
P = U x I
Higher voltage -> lower current for the same power
Lower voltage -> higher current for the same power
mikedonner avatar image mikedonner commented ·
ah yes, thank you
