Was avatar image
Was asked
Wifi not detected on EasySolar II GX
My network cant detect the Wifi for my EasySolar II GX, which was working properly yesterday.
am not sure if i made any changes that caused this as this is a new system setup and i was trying to figure things out.
Any ideas on how can i get the Wifi show up again ?
I tried the reset button but nothing changed.
EasySolar All-in-One
nickdb avatar image
nickdb answered ·
Have you tried to connect to the built in AP on the GX? This would give you access to the console and allow you to reconfigure the WIFI.
If signal isn't full then try get it nearer to the AP or consider a cable.
It is worth setting the option to restart the GX if there is no signal for 15 minutes or so.
