Doug Murdock avatar image
Doug Murdock asked
Installation orientation of MultiPlus-II 2 x120V
I don't have the vertical clearance in the bay of our class A to install a Multiplus-II 2x120V inverter. Can it be installed in a horizontal position either on its side or on its back? The installation instructions don't say how it should be mounted except that it can be wall mounted. So are there no restrictions on mounting orientation?
Doug
Multiplus-IIinstallation
Paul B avatar image
Paul B answered ·
they can be installed on there back (NOT ON THERE SIDES) however if they are working hard then extra cooling fans would help the airflow
There are two large transformers inside so side mounting is NOT recommended
