digo avatar image
digo asked
charge cycle interrupted, IP67 12V @ 25A, LiFEPO4 100Ah battery with BMS
Hello, I have a 100Ah SOK LiFEPO4 battery, specs attached.
SK12V100-0915.pdf
I'm using a Victron Blue Smart IP67 charger (12V 25A). The battery appears to be getting fully charged, but the Victron charge cycle status shows up as interrupted. I'm told it could be due to cells out of balance? Should I reduce the absorption voltage?
The battery has an internal BMS, and can handle up to 50A charging.
I was also told to limit absorption time to 30 minutes. However the setting reverts to 1 hour after entering 0 hr and 30 minutes.
battery charging
sk12v100-0915.pdf (2.0 MiB)
