kosio86 avatar image
kosio86 asked
EasySolar II better than EasySolar?
I am looking to buy a 48/5000 system and I am trying to do an educated pick between the old (cheaper) version with Color Display and Breaker box and the new Easysolar II GX with no Color display and breaker box. A third option is to have Multiplus I or II and SmartSolar but it seems that total the price gets even worse. So, could someone elaborate on why I should buy the Second version over the 1st one? I still can not find the advantages in the product description.
EasySolar All-in-One
mrhappy avatar image mrhappy commented ·
Maybe look around and get prices from more distributors. Where I am the II versions are significantly cheaper than their first version counterparts.
JohnC avatar image
JohnC answered ·
Hi @kosio86
I'm not really up on this, but I think the newer design is more suited to grid-tie application, like exporting power. And will be the one Victron offer for certification to do that. Perhaps a more 'globalised' design?
I have the older 48/5000 (nearly 5 yrs now) , and what won me was the row of onboard breakers (I needed a new switchboard anyway). Not sure if that's still there, but if you didn't want them they'd just confuse things.
The older is much taller and ~10kg heavier. One wonders where the weight saving comes from with electronic kit? And at 48kg I needed to install a lifting hook for a winch to get it on the wall.
The older design tried'n'proven, and should still be supported for a long time yet, but there are the odd (subtle?) differences that could sway you.
Paul B avatar image
Paul B answered ·
The easysolar II and multiplus II and Quattro II these are just the Latest version of the older products and in time will replace them fully I think. but for now they just have better components and updated systems and Firmware, however the Basic operation there is no real diferance,
marekp avatar image marekp commented ·
The one difference is when you want it to work ON-grid.
The new design does not need extra, and not cheap, anti-islanding device.
kosio86 answered ·
I kind of get that, but is there some new functionality that one ot the other has? Like mobile app management, canbus BMS connection. The price difference in the store I am looking at is ~500Eur and I am trying to justify it.
Officially both have the same price
https://www.victronenergy.com/media/pricelist/Web_PricelistVictron-EURO_2021-Q3.pdf
(bottom of page 3)
The new Version has a much more powerful GX device and internal NS-protection (I don't know if that is required in your country)
kosio86 answered ·
Thanks for the comprehensive explanation. I don't want to export power at first, but I would definately like to have this option at a later stage.
ejrossouw avatar image ejrossouw commented ·
The new hardware should be ever so slightly more efficient under zero load. I stand to be corrected, but I vaguely recall the decision to no longer include an AC distribution board and breakers is because of the certification complications with these in for different countries.Finally, the MPPT is now a 250/100 as opposed 150/100 on the 5kVA.
