Hi, someone managed to get
SPI port 1 available on beaglebone venus os?
I don't understand if we just need to add the spi driver (dtb/dts?) and what is the procedure.
Or it is mandatory recompile venus image.
I've managed to do this with the Raspberry pi (as have some others)...
Yes, raspberry can be used directly with SPI, but prefer bbb in this case. For now, I think test read venus info from the dbus with an arduino on BBB debug serial port and drive SPI screen. Start work for BBB, no courage to remake with RPI.
You're managed both RPI and BBB or only RPI alone ?
Sorry just the R-pi, I've only recently been aware of the BB range. R-pi is slightly cheaper looking at the RRP's.
However, I have integrated a complete BMS system using the R-pi, using the SPI to interface to the BMS chips. This has been tested up to Venus 2.72, 2.8 has moved to python3, but in doing so has dropped a few drivers that I use. The SPI driver however has been added to the opkg list, so integrating that is quite easy. Have a look at the louis van der Walt serial battery thread / project for more details.
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
35 People are following this question.
