jae avatar image
jae asked
CCGX remote screen/ additional display no smartphones or pc aloud
I have a client that has no technology and wont have WiFi etc. How can I have a simple setup of a second display screen from the CCGX inside the home on a fixed display in the kitchen for example. No control of the plant is required just a display screen of some kind but as mentioned, not on a pc or laptop. Ipad or similar not ok either as would be using WiFi. Am I better off installing a BMV-700 instead.
CCGX Color Control
Paul B avatar image
Paul B answered ·
Just a idea, but no real solution sorry
On a CCGX the only way is via a lan cable and some form of computer device. Or install a computer or similar that has a HDMI output and then a long cable (there are restrictions on the length of a HDMI cables but then that are devices around to boost that signal range
now if you had a Cerbo then you could use HDMI and a TV
