timo-san avatar image
timo-san asked
Does EasySolar 1600/24VDC have diodes on MC4 connections?
637917f4-987d-459b-951b-0e0c26bd555e.jpegThere seems to be some sort of diode on EasySolar 1600 each MC4 input connectors + terminal. Anywhere any specs, what kind of diode there is? If there is a diode, I dont need any separate diodes on PV strings, evem when panels facing different directions?
EasySolar All-in-One
Just open up the front plate ot the EasySolar and you will see all negative and all positive are joint together in the same terminal.
timo-san avatar image timo-san commented ·
Yes inside, but the connector itself + terminals each have diode markings… you see a little of that marking on my photo? not mentioned by any manuals I have read…
Matthias Lange - DE avatar image Matthias Lange - DE ♦ timo-san commented ·
No I can't se any diode symbol. Can you make a picture of what you mean?
This is how a MC4 plug looks like there is no space for a diode.
There are special plugs available but they are much bigger.
google for "mc4 solar connector diode" and you'll see.
timo-san answered ·
What does that - STOP! - markings and the —) symbols mean?
"Don't disconnect under load"
