andyc avatar image
andyc asked
two multiplus one battery
hi all
i have two multiplus 48v inverters, one 5000 and one 3000
can i have them running from the same battery and cerbo?
ive been told on facebook, i can not link the outputs as they have to be same size and firmware, just checking that is correct
many thanks
multiplus ve.bus
andyc avatar image
andyc answered ·
should say, domestic house, 5kw of solar via 250/100 mppt and approx 45kwh 48v lititthum battery
Paul B avatar image
Paul B answered ·
you cant link a MP 5000 and a MP 3000 .
You can only parallel same model units
shaneyake avatar image
shaneyake answered ·
Correct, you can not parallel as they are not the same inverter.
The GX devices only support 1 inverter so you can only have one connected. Parallel Groups are basically one big inverter.
You can have them both connected to the same battery bank, managing the battery becomes a little tricky but if it has CAN or a BMV then it will be fine. Have the bigger inverter connected to GX.
You can connect them together on one battery BUT:
- you can't connect them together at the AC output; you can only supply separate AC circuits
- to connect them both to the same GX device one of them needs to be connected through a MK3 Interface
shaneyake avatar image shaneyake commented ·
Does connecting a second inverter via MK3 work? I have tried it but could never get it to work. Have you been able to get it to work?
andyc avatar image
andyc answered ·
thanks guys, ive posted on a facebook group about my other option, and thats to run them in series.
grid to 3000
3000 out to 5000 in
5000 out to load
5000 would see 3000 as a grid supply and use its power as a power assist
one guy has said he has run into issues like this , but i might try it and see if i can resolve it
with regards to the one battery/two inverters. if the inverters are not being used to charge the battery only the mppt from solar would there still be an issue?
wicki avatar image
wicki answered ·
AndyC,
sorry for digging this up - topic is still active in German forum.
Do you mind sharing which path you chose and how it worked?
Thanks.
