michael-boogaers avatar image
michael-boogaers asked
ESS system keeps going to Passthru and ignoring battery and DC PV Input.
Hi All.
System consist of 3 * Multiplus II 48/5000 units in Single Phase.
This happened right after u[update to FW 2.73.
I downgraded the fw to FW 7.72. And problem still active. Reset system , still no success.
The error comes and goes, then it works as it should, access PV Feedback etc. when ESS is set to optimized to 35% UGF.
Other issue I picked up is when I set It to keep battery full it works complete opposite for a while(then it feeds back and uses battery).
Inverters FW update to the same versions.
Any Advice?
cerbo gx
Alexandra avatar image
Alexandra answered ·
Are you using anything like a meter in the system at all?
See FAQ #4.
Q4: Why is the VE.Bus state in pass-through?
