julsky avatar image
julsky asked
Correct Settings with SmartSolar MPPT for Ective AGM DC170S Batteries
Hi :)
Today I installed my first SmartSolar MPPT (100 / 30) and connected it to my AGM batteries (2x Ective DC 170S). Then I opened the mobile app and started with the configuration of the controller. Now I'd like to ask you whether I did well or if I'm just a stupid newb ;-)
First here you can see the battery specification:
In the app I customized the battery settings as follows (simple mode, not expert mode):
- Absorption voltage: 14.90V
- Floating voltage: 13.80V
- Compensation voltage: 16.20V (default value)
The other settings at the battery settings tab are still the default values.
Is this cone well so far? Shall I change something?
What about the setting for the load output? Shall I stay with the mode "BatteryLife"? I use the batteries inside a camper van and got also a alternative power suppliers that are loading the batteries, but I want to maximize the usage of solar power.
Thanks so far! Looking forward to your expert knowledge :-)
Julian
MPPT Controllersbattery charging
Paul B avatar image
Paul B answered ·
just follow the battery manufactures specs the specs you have imputed are there MAX figures .
YOU DO not use equalisation on AGM or GEL batteries do NOT GO over the Manufacturers voltage settings
If you are in a HOT climate or the room is over 25 deg c then the higher the temp move more to the lower voltage settings, the hotter the area the more quickly the LA batteries degrade overtime.
MPPT Product Page
MPPT Error codes
