How do I configure the color control gx to display SOC % reading in one decimal place for example 95.6% coz it rounds it off to 96%, the SOC values are obtained from the Lithium battery BMS
Hi @mlsadler
I don't believe it's possible to change this (unless you're into coding). And it doesn't matter where the SOC is sourced from.
I too would like to see it reported to one decimal place, but it's inconsistent across the monitoring platforms..
VRM has it, but not the GX or MFD app. Nor VictronConnect even on a Smartshunt, though you can count the steps in the trends graph, and you can get a decimal reading in the Battery Settings there too.
Even if it was shown alongside the full digits in a smaller size..
C'mon Victron, this would be really useful. Is IS possible to tune the shunt kit to better than 1% SOC accuracy, and 1 decimal point would be great.
Pleeaase..
43 People are following this question.
