dafyddhirst avatar image
dafyddhirst asked
Create 2nd Dbus Device from Modbus Client Script
So I have a modified script that monitors the level of an external tank via modbus TCP.
This works Great and creates the tank and posts in the data.
What id like to do is from the same script also feed data into another tank. Ie internal and also External. this is where im struggling . if anyone can help out that would be amassing.
This is the 2nd Tank id like to add
Reg_u16( 0xb203, '/ExtLevel',      1, '%.1f L')
#Modbus Tank Monitor
import logging
import device
import probe
from register import *
log = logging.getLogger()
class Reg_ver(Reg, int):
    def __init__(self, base, name):
        Reg.__init__(self, base, 1, name)
    def __int__(self):
        v = self.value
        return v[0] << 16 | v[1] << 8 | v[2]
    def __str__(self):
        return '%d.%d.%d' % self.value
    def decode(self, values):
        v = values[0]
        return self.update((v >> 12, v >> 8 & 0xf, v & 0xff))
class DSE8610(device.Tank):
    FluidType = 0
    default_role = 'tank'
    productid = 0x030
    productname = 'DSE 8610Mk2 Fuel Tank'
    min_timeout = 0.5
    custom_name = 'Tank 1'
    def __init__(self, *args):
        super(DSE8610, self).__init__(*args)
        self.info_regs =
            Reg_ver( 0x0302, '/HardwareVersion'
            Reg_ver( 0x0302, '/FirmwareVersion'
            Reg_text(0x5000, 7, '/Serial'),
    def device_init(self):
        regs = [
        Reg_u16( 0x0403, '/Level',      1, '%d L'),
        Reg_u16( 0x0403, '/Remaining',    250, '%.1f'),
        Reg_u16( 0xb203, '/ExtLevel',      1, '%.1f L'),
        self.data_regs = regs
    def dbus_write_register(self, reg, path, val):
        super(DSE8610, self).dbus_write_register(reg, path, val)
        self.sched_reinit()
    def get_ident(self):
        return 'dse%s' % self.info['/Serial']
models = {
    -32704: {
        'model':    'DSE8610MK2',
        'handler':  DSE8610,
    32832: {
        'model':    'DSE8610Mk2',
        'handler':  DSE8610,
probe.add_handler(probe.ModelRegister(0x0301, models,
                                      methods=['tcp'],
                                      units=[1]))
Modbus TCPtank monitor
