Oscar avatar image
Oscar asked
Multiplus 800 inverter settings ( DC input low shut down etc..)
Hello everybody.
Guys I am setting a Multiplus 800 connected to a 100 A Lithium battery with EXTERNAL BMS.
I have few questions about the default "inverter settings" that are the following .
Under the "Inverter tab" :
DC input low shut down=9,30 V
DC input low restart=10,90 V
DC input low pre-alarm 10,90 V
1# it seems to me this default setting is too low to protect the Lithium battery from a deep discharge > DC input low shut down=9,30 V > should I change it to a higher value like 11 V for example ? What do you recommend ?
2# the same for the other two values below . Are they too low ??!!
Thanks in advance for your help.
MultiPlus Quattro Inverter Chargerinverter current draw
You have to look in the datasheet of your batteries.
Oscar avatar image Oscar commented ·
Thanks Matthias , do I have to look at "End of discharge voltage" i.e 11,2 V and insert this voltage as DC Input low shutdown ?
