Hello
i am running a RPI with the version 2.66... i would like to update to resent version via the SSH
my RPI is not not easy to access so remote would be great
Any help would be appreciate
Hello
Hi, to update from v2.66 onwards on a pi is impossible, as it requires a re-flash, see venus os rapsberrypi document; last chapter.
for more normal situations, and updating from ssh, see our commandline manuals
If your RPI is connected to the internet, you can access the remote console either on the local LAN or via VRM. From the GUI you should be able to initiate a firmware update.
SSH does not provide an update path. You either need to use the on-line update, SD/USB memory card or refresh a new Venus OS system SD card. The later is a last resort because you loose all your configuration settings.
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
43 People are following this question.
