niccyba avatar image
niccyba asked
Set location (lat/long) using third party device?
In my trailer I have a WiFi access point with a couple of SIMs in it (one for roaming and one for home) which also has GPS. I currently feed the GPS into a homebrew system I run, but it would be quite nice if I could add it to the VRM portal as well. The API looks like it's read-only and there doesn't seem to be a way of injecting the data any other way.
I really don't want to have to buy a Victron LTE gateway and two more SIMs just to get the data in, so any other way would be very helpful (and considerably cheaper).
So, can I get lat/long information into VRM?
Cheers. Nicholas.
gps
Kevin Windrem avatar image
Kevin Windrem answered ·
You can buy a USB GPS that will plug into your GX device (Cerbo, etc.) for about $20.
Here's a list of USB GPS units compatible with Venus OS:
https://www.victronenergy.com/media/pg/CCGX/en/installation.html#UUID-3f51bfea-de8d-701d-9d5c-0c2ba67ce876
I used the Globalsat BU353S4
For other units, look for NMEA0183 support
niccyba answered ·
Lovely. Thank you.
*UPDATE* - Just found an old (must be 8 years or more) unbranded generic USB GPS stick in a pile of junk in the garage and plugged it in. It just worked. Every day I am more and more impressed by Victron!
