dirkmuc avatar image
dirkmuc asked
PIP in Venus 2.80
I just upgraded my Pi4 with Venus OS 2.80~16 large 21.
For my BME280 I need some Python modules via pip. In Venus 2.70 I could easily install it. But on 2.80 currently I have not found a way to do it.
root@raspberrypi4:~# python3 get-pip.py
Traceback (most recent call last):
  File "get-pip.py", line 24556, in <module>
    main()
  File "get-pip.py", line 139, in main
    bootstrap(tmpdir=tmpdir)
  File "get-pip.py", line 115, in bootstrap
    monkeypatch_for_cert(tmpdir)
  File "get-pip.py", line 96, in monkeypatch_for_cert
    from pip._internal.commands.install import InstallCommand
  File "<frozen zipimport>", line 259, in load_module
  File "/tmp/tmpmgq8ie1_/pip.zip/pip/_internal/commands/install.py", line 14, in <module>
  File "/tmp/tmpmgq8ie1_/pip.zip/pip/_internal/cli/req_command.py", line 21, in <module>
  File "/tmp/tmpmgq8ie1_/pip.zip/pip/_internal/index/package_finder.py", line 32, in <module>
  File "/tmp/tmpmgq8ie1_/pip.zip/pip/_internal/req/__init__.py", line 8, in <module>
  File "/tmp/tmpmgq8ie1_/pip.zip/pip/_internal/req/req_install.py", line 35, in <module>
  File "/tmp/tmpmgq8ie1_/pip.zip/pip/_internal/operations/install/wheel.py", line 38, in <module>
  File "/tmp/tmpmgq8ie1_/pip.zip/pip/_vendor/distlib/scripts.py", line 14, in <module>
  File "/tmp/tmpmgq8ie1_/pip.zip/pip/_vendor/distlib/compat.py", line 83, in <module>
ModuleNotFoundError: No module named 'xmlrpc'
Trying to install the module xmlrpc with
root@raspberrypi4:~# opkg install python3-xmlrpc        Collected errors:
 * opkg_prepare_url_for_install: Couldn't find anything to satisfy 'python3-xmlrpc'.
Was not successful.
I now that in pqkg.conf you can add a repository, but I do not know which to get the missing module.
Does someone know a way ahead?
Cheers
Dirk
Venus OS
I recommend to start with studying this: https://github.com/victronenergy/venus/wiki/commandline-introduction#opkg
If that doesn’t help, then please explain what steps you took and post the outcome of opkg update
dirkmuc avatar image dirkmuc commented ·
Hi @mvader (Victron Energy) ,
Thank you for the tip!
After changing to candidate
/opt/victronenergy/swupdate-scripts/set-feed.sh candidate
And
opkg update
I could install the missing Python module and then install pip.
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ dirkmuc commented ·
nice!
