drdiesel avatar image
drdiesel asked
Is my MK3-USB Faulty?
Please see the attached unlisted Youtube video.
Basically when I plug the ethernet cable in to the MK3 the inverter faults, unplug the cable from the MK3 it will recover ~20 seconds later. I've ensured the cable is not faulty, tried a few different ones, all none crossover.
When I first plugged the MK3 usb cable into the computer and ran VEConfigure3 the software found it no problem and asked to update the firmware which was successful.
Video link
https://youtu.be/54naMCYx7w4
MK3
drdiesel answered ·
New MK3 showed up today and everything is working as it should.
Issue was faulty MK3.
The Victron tool kit app says VE.bus error 14.
Try to use the other VE.bus connection in the Multi and check if there are contacts bend together.
drdiesel avatar image drdiesel commented ·
Thanks, I tried the second VE.bus port and also tried a different a Quattro 48/5000, all results are the same.
This is a brand new MK3, so no previous functionality.
shea avatar image
shea answered ·
What operating system? There are some mixed compatibilities in the Docs.
kerbal avatar image
kerbal answered ·
I have the same problems here. When I connect the MK3 USB to my Multiplus 2 I get error 14 (device cannot transfer data). If I use the same cable and connect the Multiplus II to my Cerbo GX, everything is fine.
I have now set up my Multiplus II with VRM Remote VEConfigure. Works pretty well and my system is up and running now. I have ordered a new MK3 USB and will check again.
