I have lost power on pin 4 (Power +) of the VE Direct port. I still have data coming through but no power. Is there any way to test or repair this further or does it mean replacement a unit is required?
Might there be an internal schematic available so I can better understand where this small voltage comes from?
A small 5V regulator is followed by a 10Ω resistor, so not too much current otherwise the Voltage drops at the output with increasing current.
The 5V pin is intended to drive a digital isolator at the other end of the VE.Direct cable or within the VE.Direct USB cable, so not much current is ever intended in the design.
56 People are following this question.
