Do I need to wire both the Smartsolar MPPT 75/10 with the Smart Shunt? Or do I only need to use Smartsolar MPPT 75/10?
Does the Smart Solar charger do everything the Smart Shunt does?
the shunt is only in combination with a BMS. a shunt alone wont charge anything - or maybe I misunderstand your question?
The Smart Shunt gives you information on ALL power in and out of you storage (battery(s)). I don’t have a Smart Solar Controller, but without the shunt I don’t think it gives you usage information. I am sure somebody who knows better will tell us though! Hope that helps.
28 People are following this question.
