nelsonpk avatar image
nelsonpk asked
BMV-700 SOC
Simple question.
Should the SOC% match the bar graph in the bottom RH corner of the gauge?
Ie, 3 bars = 60%, 5 bars = 100%
I believe the bar graph is probably correct & my SOC % is not for some reason.
I don't have BT so can't screen shot settings.
SOC
It is linked to the setting 16. SOC relay (discharge floor).
Full = 100% and empty = you reached the SOC set in setting 16.
4 comments
nelsonpk avatar image nelsonpk commented ·
#16 setting is 85%.
Currently SOC is reading 91.9% & bar gauge showing 2 bars so assume 40%.
Matthias Lange - DE avatar image Matthias Lange - DE ♦ nelsonpk commented ·
If setting 16 is 85% then you have a range of 15% from 0 to 5 bars.
85% = 0 bars
88% = 1 bar
91% = 2 bars
94% = 3 bars
97% = 4 bars
100% =5 bars
nelsonpk avatar image nelsonpk Matthias Lange - DE ♦ commented ·
So to match The SOC it should be set to 0%
In reality 10% for lithium battteries to show actual power available.
You should it set to a value you normally want to stop discharging.
(50% for lead and 20% for lithium or whatever the manufacturer recommends)
nelsonpk answered ·
I think I am starting to understand this stuff now.
Thanks for the help
