Venus OS v3.60~60 available for public testing
Good morning
There is a new series going into public testing: v3.60~x.
Change log below, first please make yourself aware with the beta testing instructions:
Instructions 1 of 3: Venus OS beta testing & how to join/install
In case you don’t know what this message is about, please start with reading this link, which explains the Venus OS beta program. Venus OS is the software running on all our GX devices, such as the Cerbo GX.
Instructions 2 of 3: How to report an issue?
Before posting, please check if your issue already exists, in which case please contribute by replying to that issue or up-voting it.
Only once you are sure its a new possible issue, start a new topic.
Lastly, before posting, preferably first revert to the latest official release, to double check if the issue you’re seeing was present there as well. Regressions require a different treatment than other issues and bugs. And let us know if you did that, and what the difference is. A perfect report contains:
  • How its expected to work
  • How it doesn’t work as expected
  • Details on the system
  • What you’ve already tried to make sure its not a setting or other issue.
Please take note that that this works quite differently than it used to do on the old version of Community:
  • For a new issue, open a new topic. Instead of adding a new reply at the bottom.
  • To add to an already open issue, aka topic, reply to that. Or just upvote it if you have the same issue. This will help us a lot in determining its importance and manage our priorities.
Instructions 3 of 3: using Node-RED, Kevin’s SetupHelper, GuiMods or other add-ons?
In case you are running Node-RED or SignalK, then please at least say so in your bug report.
Kevin’s GuiMods and other 3rd party add-ons: don’t report your gui issues here. Please do it elsewhere instead; and make sure to check out the related issue tracker first.
Changes made by us can cause a compatibility issue with the GuiMods; and these betas report pages are for official firmware only.
Change log
v3.60~60
  • Multis & Quattros VE.Bus
    • Clear phase rotation warning when AC input is ignored, unit is switched off or to inverter-only
  • Multi RS & Inverter RS
    • Fix incorrect DC Load numbers on GX UI
    • Add current produced by built-in MPPT to Current summary (visible when users select to see current rather than power on the GUI). Before this change, the DC current coming from the built-in solar trackers wasn’t visible.
  • In the past, the current made by the RS was not shown if you selected the Current view on GUI-v2.
  • Dynamic ESS
    • Fix device selection when having more than one Multi/Quattro system connected to the GX. Now it select the device with the lowest device instance, similarly to how DVCC and other features work.
    • Increase hardcoded 32kW to allow import/export at higher power values
Venus OS Large
  • Victron Node-RED pallette, node-red-contrib-victron v1.6.23 & v1.6.24
    • Virtual switch: improve naming
    • Extra examples
  • Node-RED v3.1.4 & 3.1.5
    • Minor version bumps to sync with latest 3.x release.
v3.60~59
  • Fix Cerbo GX MK2 VE.Can 2 port issues. A while back we’ve already released a an improvement for that issue, but that still left a certain percentage of units failing, with the remedy being to RMA/replace them under warranty. OK - but not good.
    Now, we’ve finally been able to, in software, find a fix that promises to be a 100% solution. Also VRM data this morning confirms it: all units that had issues running v3.60~58 yesterday, and now updated to v3.60~59, report a 100% operational VE.Can 2 port. More testing is needed to be 100% sure, but so far all signals and results are promising!
  • Comap genset integration: Fix oil pressure scaling
  • Energy meter VM-3P75CT: future firmware related improvements
Venus OS Large
  • Node-RED Victron pallette, node-red-contrib-victron 1.6.23
    • virtual-switches: add extra paths
v3.60~58
  • Fix bug, introduced in a recent v3.60 beta, that causes some MultiPlus models to turn on by itself.
v3.60~54 till v3.60~57
Fix a few regressions, ie. bugs introduced during earlier v3.60 beta versions:
  • Fix access point feature
  • Fix VictronConnect on local LAN feature (an MQTT error would show).
Multis/Quattros VE.Bus:
  • Clear phase rotation warning when AC input is ignored, inverter is switched off or set to inverter/only.
Multi RS:
  • Improve state shown for systems consisting of multiple units.
New UI:
  • Change how warnings, alarms and other notifications are shown. Previously the display would move away from wherever it was to the notifications page. Which can be quite annoying while diagnosing an intermittent problem. Now it doesn’t change pages, but instead shows a toast/popup while leaving the user on the page where she/he was.
  • Add feature that allows to select individual batteries and tanks for the Brief page center gauges
  • Improve performance of Brief side panel load graph
  • Fix save value when customizing Brief center temperature service
  • Update breadcrumb titles when language changes
  • Show custom name of digital input in device list
  • Fix typos in Arctic and Antarctic time zone names
Genset start/stop
  • Better handle systems having multiple gensets. The start/stop features will work with the genset having the lowest device instance and ignore the others.
Venus OS Large / Node-RED
  • Victron node palette aka node-red-contrib v1.6.22:
    • Add missing temperature types for virtual temp device
    • Add info fields for virtual battery
    • Fix in installing example flows
v3.60~50 till v3.60~53
  • Fix Cerbo MK2 wifi issue. For users that can’t update because they are running a prior beta version where the wifi is too unreliable to install a firmware update, install the update using an SD Card, USB stick or connect an ethernet cable.
  • Fix Node-RED dashboard issues
v3.60~49
New UI
  • Fix changing of access level, thank you @pwfarnell for your report
  • Various other small changes
  • Update translations
Classic UI
  • Fix various styling issues
  • Fix issue related to the Atlantic Standard Time and Halifax: the timezone “Atlantic Standard Time (Canada)” has been renamed to Atlantic Daylight Time (Canada). A new time zone, “Atlantic Standard Time”, has been added which does not observe daylight saving time. Users in that timezone must select the new one for the correct time to be displayed the year round. The same change will be made to the New UI soon.
  • node-red-contrib-victron 1.6.21
    • Fix relay control node, thank you @AdrianChen for reporting
v3.60~48
  • No changes to the installed image
Developers
  • re-add various opkg installable packages that had been missing since a few beta versions back.
v3.60~47
Dynamic ESS
  • Improve how Dynamic ESS reacts when actual consumption or solar production differs from forecasted. For example when there is more solar then expected, the updated algorithm will in many cases use that extra solar power to charge the battery, even if that would exceed the planned SOC level for the current hour. Instead of feeding that excess solar back into the grid for a low price, to later have to buy it back at a higher price.
Security and other improvements
  • Disable no longer recommended TLS 1, TLS 1.1 and DTS 1 system wide, by defaulting to minimal TLS2 and cyphers as recommended by Mozilla, see Security/Server Side TLS - MozillaWiki.
  • Update the used MQTT broker to FlashMQ v1.20.0
  • node-red-contrib-victron 1.6.20
    • Fix in setting initial state for enum values
v3.60~40 till v3.60~46
Marine MFD HTML5 app
  • Add night colors support (everything RED, for when using this in the dark).
  • Add support for GUI-v2 on devices that support it
  • Improve layout on High DPI screens (Garmin 9000)
  • Improve support for systems having multiple connected Multis/Quattro’s.
New UI / gui-v2
  • Various fixes and improvements to the recently updated Settings menus.
  • Always show battery SOC percentage or Temperature in Brief center (instead of only when there is one gauge).
  • Move gps devices into the device list
  • Generators: add new “Stop generator on Tank level” condition
  • Display VRM device heartbeat information in splash view
  • Fix being unable to open any settings pages if access level is “User”
  • Show modifications page only when is backend available
  • Show a toast notification when the relay function is changed
  • Clip main view on desktop as well as wasm
  • Fix loading of Device Info page from PageAcInModel
  • Rename zero feed-in limit to dynamic power limit
Energy Meter VM-3P75CT
  • Reduce GX CPU load required when measuring (by only doing high-speed data when used as grid meter). For now only when the meter is connected on VE.Can, the same improvement will be added for when connected on Ethernet soon.
  • Victron node palette, aka node-red-contrib-victron, v1.6.17 → v1.16.19. No significant changes.
  • Signal K Server: add the documentation back
Developer
  • Fix missing opkg packages. Issue was introduced per v3.60~39.
v3.60~26 till v3.60~39
Remote VEConfigure
  • Fix VeConfigure cannot open remote file with special firmware versions such as S99 for external transfer switch
  • Fix occasional configuration fails with error 46 (uploaded file does not match model)
New UI aka gui-v2
  • Add solar & wind priority feature
  • Add page to allow checking if a system was modified or not + links to obtain support
  • Brief page: allow setting the center gauge levels to be set to None, which for example makes it possible to see only battery SOC in the center, and have the tanks on the levels page only. Further improvements and configurability of that center gauge is on its way
  • Brief page: show amps instead of power, in case amps is the chosen preference in the settings
  • Various other small improvements and fixes
DVCC
  • Do not force SVS off for BlueNova batteries
    Users can now select their own setting, if they prefer to use SVS. Our recommendation remains to leave SVS off.
Genset start/stop
  • Add feature to stop the genset when the tank level is below X; to prevent continuing to run until tank is empty and air is in the system.
Wakespeed speed integration
  • Fix field drive, add utilization and engine RPM via J1939
Hatz DC genset integration
  • various improvements
Venus OS Large
  • node-red-contrib-victron v1.16.16 & v1.6.17:
    • Update of underlying library, reducing dbus traffic for virtual devices
    • Reduce amount of installed files
    • Fix in data type for some paths used by the virtual devices
    • Add null-values support to invalidate dbus paths
Developers / under water
  • update OpenEmbedded from Dunfell version to Scarthgap. Which brings all the underlying used packages and software inside Venus OS up to date. This does come with a slight increase in CPU and RAM usage. Therefore, on already near overloaded devices, especially in case its a CCGX, this might result in a no longer functional and/or continuously rebooting system. Worst case, reduce the load by disconnecting the connected equipment, and revery to Venus OS v3.54.
  • watchdog: increase the max-load5 to 10. The watchdog should only react in completely runaway cases. During boot and with the large image image there can be temporarily quite overloaded cases, which shouldn’t trigger the watchdog early. They ought to settle over time or other wise the load15 will catch them.
  • add htop as optional installable package
v3.60~25
  • Tank inputs on Cerbo GX, Ekrano GX GX Tank 140: Increase margin on analog input open circuit detection, fixes tanks showing an “Open circuit” alarm while all that happened was a sensor that is a bit overshooting / out of range.
  • Login page for gui-v2: fix iOS zoom in on page.
  • Various other small fixes
Developers
  • drop support for qt4 in the SDK, since it is no longer used nor included in Venus OS
    v3.60~22, 23 and 24
ESS
  • fix issue in peakshaving feature in combination with the Self-consumption from battery setting set to Only critical loads
  • fix problem where loads were not powered from PV when ESS mode is optimised with minsoc=100%, unless the battery actually reached 100%. Thanks to @nickdb. (introduced in previous beta version)
Managed batteries:
  • Add support for Soluna batteries
Genset start/stop:
  • genset start/stop: add a new alarm feature “Detect generator at DC”
    • When the setting is enabled, an alarm will be triggered if the DC current read by the genset has not been above 5A once for 300s. As soon as the current has been above 5A once, the genset is considered running properly, until it is stopped again.
    • Only visible for digitally connected DC gensets, such as Fischer Panda and Hatz.
    • Here is a screenshot of the new setting and the new alarm:
Venus OS Large / Signal K server
  • signalk-venus-plugin v1.42 → v1.43
Modifications:
  • gui-v1: Add log entry if loading QML files failed, more specifically gui-v1 now reports to the console if an error occurred during initial parsing. This won’t catch errors in pages which are loaded later on, for example the overviews. But does catch errors in components; and allows add-ons like gui-mods to be more robust/foolproof.
v3.60~21
  • ESS: fix issue where MPPTs stop generating when minimum SOC is set to 100%.
  • DSE Genset start/stop integration: support for more models, including DSE7320 and DSE7320 MKII. We now support all applicable DSE models. The range not support is the DSE8000 range, which is a more advanced range used for paralleling gensets.
  • Remote firmware updates: fix issue where only one VE.Direct device (mppt, battery monitor, smartshunt) was found when scanning; as was as improve the status indication as visible on the VRM Portal
  • node-red-contrib-victron 1.6.15
    • Fix issue preventing virtual GPS device from functioning
    • Update services: Added several extra paths to the acsystem and acload nodes
    • Make temperature optional for virtual batteries
    • Update dependencies
    • Update documentation
    • Add ability to assign single phase virtual PV inverter to any of L1-L3 phases
v3.60~18, ~19 and ~20
  • gui-v1 underwater improvements (built against a newer version of the graphics library)
  • PV Inverter zero-feed-in
    • Fix problem with Zero-feed in limit stuck at 1064 W for Solaredge SE 66.6 K
    • Fix issue in SMA limiter, especially related to TriPower inverters.
    • With above two changes, all known issues of this new feature (see below in the changelog for details) are now fixed: feedback welcome!
  • Remote Firmware updates over VRM
    • Significantly increase the speed of scanning devices for firmware updates. On a simple test system with a Cerbo GX and one of each device, scan time was reduced from 44 seconds to 16 seconds.
  • gui-v2
    • Complete re-layout of the settings menu
    • Add language Zuid-Afrikaans
    • Change the number of decimals for the tank sensor empty / full settings, in a future update we’ll make sure that the sensor value field shows the same number of decimals.
    • Fix issue related to GPS device instance display
    • Fix Maximum ESS Grid Feed-in could be set to -1
    • Add confirmation dialog to Generator Settings auto start functionality
    • Do not show generator control cards when generator is disabled
    • Add missing ESS menu to RS System Page
v3.60~17
  • gui-v1 Remote Console improvements (feedback wanted! both when having issues, but also its great to hear that Remote Console, Classic UI aka gui-v1, works well for you).
Venus OS Large
  • node-red-contrib-victron v1.6.12
    • Add support for a virtual GPS
    • Add /Connected to virtual pv inverter
    • Add text representation for tank level
    • Library and documentation update
v3.60~16
  • gui-v1: various small improvements regarding connection stability and handling first key stroke and mouse event
v3.60~12 till v3.60~15
Multi RS:
  • Fix spurious grid lost alarm
New UI
  • For systems having a second VE.Bus System, connected using an MK3-USB, DVCC parameters may now optionally control all systems. A new setting has been added to enable this; disabled by default.
  • Hide phase data for vebus inverters with no valid AC inputs
  • Hide equalization, state of charge and active input settings for non-multi vebus inverters
  • Fix Device type page titles
  • Add a watchdog timer to detect crashed WASM and trigger reload (WASM only).
  • Add position setting for energy meters proxying for EV chargers
  • Clip GradientListView to avoid out-of-geometry delegates stealing clicks
  • Fix bugs in generator state display
  • Fix spinbox buttons display in disabled state
  • Hide minsoc control if battery is kept at 100%
  • Add scheduled charging controls for RS devices
  • Add a breadcrumb navigation header in Settings pages
DVCC
  • Add Sunwoda battery support
v3.60~11
  • Small internal change related to Cerbo GX MK2 VE.Can Port 2 status reporting
v3.60~9
  • Change the (per v3.60 newly introduced, see below) PV Inverter limiting behaviour for SMA inverters. The algorithm no longer auto-enables the feature on the SMA inverter, and therefore it is now necessary, if you want to use this feature, enable External limiting via Modbus TCP in the SMA settings. The GX will now not show the limiting option in its settings unless the SMA is configured for External limiting. Fixes error 10120 being raised on the SMA inverter.
  • A few small further improvements to the Cerbo GX MK2 VE.Can port 2 software improvement.
  • New UI: Fix virtual keyboard no longer working - this was broking earlier during v3.60 betas.
v3.60~8
  • Fix Cerbo GX MK2 VE.Can 2 port failing after some time on a certain percentage of units, especially when running the New UI (gui-v2)
  • Fix genset start/stop not working always, bug was introduced earlier during v3.60 development
  • Fix Multi RS grid lost alarm; that alarm mechanism is now configured with the common Settings → System setup → Monitor for grid failure setting.
gui-v2
  • Respect access level in various device list controls
  • Fix generator start/stop conditions battery monitor selection menu
  • Add control card for EV Charger
  • Add support for Utilization reporting for Alternator (visible for those alternator controllers that transmit that data)
  • Use Slider control for RS ESS min-soc setting
  • Show active SOC limit on ESS subpage
  • Move ESS menu to Inverter/Charger page
  • Fix listing of PV inverters on the system
  • Increase tank sensor value limits precision (when full and empty) to 3 decimal places
    and the step size to 0.005
  • Add connectivity icons for WiFi and GSM
NMEA2000-out
  • N2K-out: add VREGs for AC in/out current to VE.Bus sender
v3.60~5, 6 and 7
New UI aka gui-v2:
  • Fix the max gauge range setting for AC input 2 current gauge
  • Fix bug wrt input current limit control for External transfer switch type systems; the controls page showed a second input current limit setting while there is only one.
ModbusTCP:
  • Add 32-bit registers for a number of services that have outgrown their 16-bit values
    • Battery DC power, register 256. Used to be limited to 32kW.
    • Solar charger PV power, register 792. Used to be limited to 6553.5kW.
    • Generator power, registers [3230-3235]. Used to be limited to 32kW per phase.
    • AC load power, registers [3924-3929]. Used to be limited to 32kW per phase.
Venus OS Large - Node-RED
  • Victron pallette, node-red-contrib-victron v1.6.3
    • Update enum of inverter mode
    • Bump in underlying libraries
v.3.52 → v3.60~4
General:
PV Inverter integration:
  • Re-add the new setting and feature that was also tested in the v3.50 beta series for a while: PV Limiting support for PV-inverters other than Fronius and ABB/Fimer, who were always supported.
  • Note that the setting is only available in gui-v1 at the moment, it will be added to gui-v2 shortly.
  • Details:
    • This setting shows only for PV Inverters other than Fronius and ABB/Fimer. For Fronius and ABB/Fimer nothing changes: PV limiting remains always enabled as in the past.
    • The setting shows up for any PV-inverter that advertises the limiting ability through the SunSpec protocol.
    • The setting also shows up for some SolarEdge inverters. SolarEdge use their own proprietary limiting protocol.
    • This feature will interfere with proper operation in a SolarEdge/SMA system with an energy meter. Leave it disabled in such systems.
    • This setting defaults to Off. The objective is to avoid silently/unexpectedly enable the limiter on a running system when Venus OS is updated.
    • Note that enabling this setting only makes the GX “limiting aware” for the said PV Inverter. Thereafter, to actually enable limiting, either Disable the feed-in of excess AC-coupled PV in Settings → ESS, or use Dynamic ESS.
    • For Fronius and ABB/Fimer, nothing changes. PV-limiting support remains enabled and there is no setting for it.
  • Compared to the version last in v3.50 (v3.50-42):
    • Fix bug that caused support for limiting to not be indicated (introduced in venus 3.50~40)
    • Fix bug that required a reboot after disabling the limiter
New UI aka gui-v2:
  • Show multi-phase solar inverter output in watts not amps
  • Fix bug in Bluetooth sensor configuration menu that could cause sensors to no longer show in a webbrowser until restarting the browser.
  • Update translations.
Multi RS:
  • Fix grid-lost alarm showing even though disabling in Settings → System
  • Add Multi RS specifics to GX genset start/stop feature:
    • Warm-up and Cool-down support (ignore AC input to allow the generator to warm-up or cool-down without a load)
    • Start/stop conditions on Inverter overload, Inverter temperature, AC load
  • Fix various smaller issues
Modbus-TCP:
  • Add register for Multi RS ESS Active SocLimit
    • This is the actual minimum SOC the system is using, it can be different from the Minimum SOC setting if BatteryLife is active
    • register 4926, uint16
  • Add registers for AC input current limits for RS-systems
    • Register 4940: AC input current limit for AC-in-1
    • Register 4941: AC input current limit for AC-in-2 (for future models)
    • Register 4942: AC input current limit at the meter
Managed batteries:
  • Reword high battery voltage alarm into High cell voltage alarm since that better indicates the issue. In 99.999% of situations this indicates an imbalance issue in a battery/bms combination that apparently doesn’t automatically handle this in way while preventing high cell voltage alarms/situations, consult your battery documentation on how to restore cell balance.
Venus OS Large - Node-RED:
  • update victron node pallette to v1.6.2
  • update vrm node
  • update Node-RED from v3.1.10 to v3.1.13
Venus OS Large - Signal K Server:
  • update signal k server from v2.11.0 to v2.12.0. Change log.
  • update venus-signalk-plugin from v1.41.0 to v1.42.0. Change log.
Good evening, per just now a new version, v3.60~7. Small further improvements, details above.
Good day, per just now: Venus OS v3.60~8 available for public beta testing. Have a good weekend!
What does below section mean in detail?
Thank you
  • Improve Meteo sensor support
Hi @ppr ,
The meteo change is actually some under water / future preparation change. I’ve removed that from the list.
The addition of a EV Charging Station (EVCS) control card means that its now possible to control an EVCS from the control panel. See red circle for that that means:
Hi Matthijs,
any way to have tank sensor value in decimals also for litres and not only for m3?
Thank you
Matthias, today I replaced a Cerbo GX on our demo wall with a Cerbo GX MKII that I had replaced on a customer system because we thought it was faulty. Loaded 3.60~8 on this MKII and our system has been stable. On 3.52 VE.Can 2 would drop out within 20 minutes. FWIW, we have a Pytes BMS on VE.Can 2 and two MPPT RS 450/200 on VE.Can 1.
I’m glad for the software fix so this MKII can come out of the NFG pile :slight_smile:
Unfortunately there is no additional card visable in my installation. Any presettings needed?
Regards
Dirk
this morning the new card appears.
Good day all, a small update: the v3.60 betas also include adding proper GX start/stop support for systems using a Multi RS.
The changelog has been updated to include that now:
Included per v3.60~4:
Hi Ed,
ok that is very good feedback to hear! thank you.
Thank you for the update. Everything is running here fine.
2x RS 450/100 and 3 Multiplus 2 3000W and 45kWh Battery
I live in Sweden. Only in the calculating of dynamic ESS is sometimes wrong/scary.
Till 6 o’clock around 10ct. Load only 2 hours in this gap and discarge from 5-6. at 7 o’clock start loading again on 13ct and 21ct. 7:30 SOC 77%
For me Dynamic ESS has a lot of potential to save money.
No critic, only a finger lifting on the function, where I see potential to make us all happier
Thanks for the good support and releases!
Martin, near Älmhult Sweden
Hi all, a new version is available as a public beta: v3.60~9. Changes include:
  • changes to (the new) PV Inverter limiting feature related to SMA
  • Further fix of the Cerbo GX MK2 VE.Can Port 2
  • Virtual keyboard for New UI aka gui-v2
Details above
I noticed the grid feed in limit goes to -1 instead of 0 then when you increase the limit again it goes in steps of 99 watts instead of 100 watts.
Good evening, v3.60~11 is available for testing. Compared to the previous version there is one small internal change that we were keen to get out. Details above.
Have a good evening!
I have installed the latest version of Venus Beta, 3.60.11. The VRM works fine, but the remote console isn’t working. Has anyone else experienced the same issue?
Thx
For me both the old and new GUI are working with the remote console and beta 3.60~11
