User-configurable settings for ESS mode, minimum state of charge limit, and AC-in current limit
Generator start/stop with warm-up and cool-down
Dedicated Node-RED flows for controlling this Multi RS model
Note that for this same Multi RS model, updating to the firmware v1.32 is required, which is important for any systems running Dynamic ESS.
Changelog
For the complete list of changes included in this version, see the Venus OS folder on Victron Professional.
How to install
For GX devices connected to the internet, see the Settings → Firmware online update menu. For GX devices not connected to the internet, the update can be installed using SD-card or USB stick.
with this update I noticed that the settings from Settings >> General >> Display & Appearance >> Start Page settings are ignored upon any error logged there.
For context, after a Grid Lost alert, I will login to the Notifications, Silence the alarm. After the grid connection is established, the start page remains the active as the Notifications page where all the past alarms were shown but resolved.
I am having a display connected via HDMI to Cerbo-GX and is annoying not seeing my default set page (Brief, in my case) when the timeout os reached.
Restarting the Cerbo-GX also disables the timeout settings and asks also to select “again” between the new ui vs classic.
Happens only when you have any new notifications, and then after to resolve/see them the timeout default view page is ignored.
