I currently have a Victron MPPT 250/70 with 2x MC4 connectors.
I also have 8x 410Watt Canadian Solar panels connected as 2 Series of 4
In winter the solar panels does not generate much power as expected but in summer it runs great.
Can I add another 4x 410 watt Canadian Solar panels to help boost my winter Power Generation without overloading the MPPT in Summer as the total is 4920Watt and the Specs sheet shows only 4000Watt @ 48volt battery system. The Inverter is a Victron Multiplus II GX 48/3000/35 and I have 5 US2000 Pylontech Batteries I am trying to charge.
Do I need another MPPT or will the 250/70 just reduce Solar panel power in summer.
