Any setting changed from default sends the device in to an unwanted state makes lots of sound. (heavy transfo brom on and of like a sirene)
Settings as small as charger max output 120A -> 90A, or select the correct batteries, device resets and the sound comes on and output main is not correct.
only fix is to ve.flash the device to get to default factory, change the made setting back does not change the state firmware 2615485
I uploaded a video see to believe :)
Device list: (single fase) 15A grid power
Cerbo connected ethernet to router
Bmv-712 (2000A shunt) ve.direct to Cerbo
Multiplus II 24/5000 connected to Cerbo ve.bus
multi control 200 connected ve.bus to cerbo
grid meter ET112 connected to rs485 USB cerbo
8x 265Ah Gel/agm victron connected to Multiplus by 4x 95mm2 Cable.
Ac out 1 used. charging and inverting tested and works.
![fr.jpg](/storage/attachments/23287-fr.jpg)
on the AC out 1 their are 2 enphase IQ7A with 445WP solar pannels (real time 100-700w 230v)
every change to the multi sends it in to that mode sound see video, solar and all other deviced not connected at the time of change has also been tried
