sbuchanans avatar image
sbuchanans asked
MultiPlus 12/3000/120 overload light comes on with no load
Problem, If I leave my Multiplus inverter on overnight with no shore power and nothing turned on the overload red light comes on ( I do have the remote panel). The only way I can reset it is to turn the toggle switch to the off position but the red light stays on, then go to the inverter and turn it off there for a short time. When I turn the inverter back on and go back to the remote everything works fine. I have 3 Battle Born 12V batteries hooked up to the inverter. I would appreciate the Help!
basil katakuzinos avatar image
basil katakuzinos answered ·
Overload only comes on during an overload or low battery warning. Can you just confirm from the manual which light combination you are experiencing.
Manual (victronenergy.com)
