scfoster avatar image
scfoster asked
3Kw Multiplus beeping with shore power disconnected
3KW Multiplus installed on sailboat with 300Ah LiFePO4 batteries, Cerbo GX and color display.
When disconnected from shore power the Multiplus begins to beep and does not stop, even for an hour, until reconnected to shore power.
Is there some setting to eliminate this? Is there another issue I need to address?
alarm
batak avatar image
batak answered ·
in your GX go to System Setup and disable "Monitor for Shore Disconnect"
Are you sure it is coming from the Multi? The Multi don't have a speaker to beep.
Like batak said I also think it is coming from the GX device because the grid lost alarm is activated.
scfoster answered ·
Ask and ye shall receive... thanks guys. Page 26 of the Cerbo GX Manual:
When there is an alarm on the Cerbo GX or a connected product, the Cerbo GX will beep - unless this setting is set to 'Off'.
Too bad it doesn't appear to have a timer to beep for only a set amount of time.
