I just applied a new firmware update to my 150|100 Solar Charger MPPT from Victron via bluetooth with the Victron Connect App. Since that time, my Solar Charger will not out put any current from the charger to my batteries, no matter what I do.
The update applied was the 1.56 update, but then I saw today, there was another one, the 1.59 that I also just applied as well... hoping it would fix the issue. It didn't.
My configuration shows between 18.8-20v from the PV array, but 0 amp output. The battery voltage in my system (shown by my smartshunt) shows 11.8 and 12v, but the MPPT thinks the voltage is 14.
The MPPT only stays in absorption mode, but does not output any power at all. I multi-meter tested the output from the device, and it matches whatever voltage I set the absorption voltage to via the Victron Connect app.
I've really liked my gear when it works - but I am admittedly really frustrated that a single firmware update can take down my entire off grid system. Seems really irresponsible and there should at least be a way to revert back firmware.
Images available here
https://drive.google.com/drive/folders/1xcKa4G3L1ZldmAeDHXvpdrHIdptGZX6I?usp=sharing
