ejm avatar image
ejm asked
Quattro Fault
There is power from the battery bank, but Quattro is blocking it. I tested the terminals at the Quattro and it shows there is plenty of power. The only way I have electric is when I run my generator, it also will not let my generator charge the battery bank. Only my panels will charge the battery bank. I also see an error code # 24 System protection intitated. Please help
basil katakuzinos avatar image
basil katakuzinos answered ·
Error 24 is a verry rare error and normally indicates an internal failure of a component of the Quattro, would strongly recommend contacting your Victron installer for assistance or warranty repair/replacement.
I have linked the VE.Bus error codes so you can read for yourself what the causes of this error are.
VE.Bus Error Codes [Victron Energy]
basil katakuzinos avatar image basil katakuzinos commented ·
Some diagnostics can be performed as outlined in the Error codes manual in my above message. If you are not confident to do these and do not have a comprehensive understanding of the quattro and the system, I would strongly recommend asking a solar installer to do this.
