ctheos avatar image
ctheos asked
Load Output "Always On" during Bulk Charging
I am working on a project where it is essential for the load to be constantly running. I am just wondering whether the load will still be on when the bulk charging is turned on as the description for bulk charging is to "deliver as much charge current as possible to the battery". The current limit itself should not pose a problem
MPPT ControllersMPPT SmartSolar
ttbb avatar image
ttbb answered ·
Yes the load output is always on even during bulk charge when set to always on. The only time you should encounter an interruption of the load output set to always on is when the controller is getting a firmware updates.
