dhunt90 avatar image
dhunt90 asked
BMV-712 power cable
Hi There,
For the power cable that comes with the BMV-712 that connects to the b1 terminal. Does this cable need to be connected directly to the battery terminal or could it for instance be connected to the end of the positive cable coming from the battery where it first meets a bus bar?
thanks in advance
BMV Battery Monitor
devodave avatar image
devodave answered ·
@dhunt90 Best practice is the battery itself for greatest accuracy, however if your positive cable is adequately sized and relatively short then that should be fine.
dhunt90 avatar image dhunt90 commented ·
thank you for the response. The battery cable is 2/0 and about 8’ long. Do you think that will be sufficient?
