this are scheenshots with 46 W in the evening, I will add one of the settings when I return
See the numbers I have placed on the picture below and refer below comments.
1. the Battery IS WAY over discharged (if its lead acid it should never go below about 12.2 volts or 50% of its capacity, over discharge causes drastic reductions in life span).
2. the daily yield is the same or similar for all days, so its yield seems fine.
3. you will notice that as each day has passed that the Min voltage is less and less per day
4 days ago the battery was full basically at 14.12v Peak voltage after that its been a downhill run. but solar yield has stayed constant,
So to me it seems You are using more power than your solar system is producing thus your battery is going flat over a period of days
its the same as water tank, as a example see below
if its a 200 ltrs tank and you take out 100 ltrs each day and put only 50 back then after 4 days you will have a empty tank or water
27 People are following this question.
